enable mirror to remote-ip
enable mirror {mirror_name} to remote-ip
remote_ip_address {{vr} vr_name} {priority
priority_value} {from [source_ip_address |
auto-source-ip]} {ping-check [on | off]}]
Description
Enables traffic to be mirrored to the specified remote IPv4 destination
address encapsulated in a GRE tunneled packet.
Syntax Description
mirror_name
Specifies the mirror instance name. |
remote-ip
Specifies to send mirrored packets to
specified destination remote IP address. |
remote_ip_address
Specifies the remote destination IP address
for mirrored packets. |
| vr |
Specifies a virtual router of the remote IP
address. |
| vr_name |
Specifies the virtual router name. If not
specified, VR of current command context is used. |
| from |
Configures source IP address of encapsulated
mirrored packets. |
| source_ip_address |
Specifies the local source IPv4 address for
encapsulated mirrored packets. |
| auto-source-ip |
Automatically use source IP address of
egress VLAN to be used to reach remote IP address. |
| ping-check |
Configure ping health check for remote IP
address. |
| on |
Only send mirrored packets to remote IP
address if periodic pings to remote IP address are successful (default). |
| off |
Send mirrored packets to remote IP address without any
ping health check, assuming MAC address and port of next hop IP address are static
or learned. |
| priority |
Configures a unique priority value for each redundant
remote IP address of a mirror instance. |
| priority_value |
Sets the unique priority value for the remote IP address.
The priority value must be unique for each remote IP address in the mirror
instance.
The range is from 1 (least preferred) to 100 (most preferred). The default is 50.
Default
If a VR is not specified, the VR of the current command context is
used.
Ping health check of the remote IP address is enabled unless otherwise
specified.
The default priority value is 50.
Usage Guidelines
This command enables hardware mirroring of Ethernet frames to a specified remote IPv4
address, which can reside zero or more router hops away. This is useful for ExtremeAnalytics
Application Telemetry or other forms of remote network analysis or monitoring.
Port mirroring configures the switch to copy all traffic associated with
one or more ports, VLANS or virtual ports. A virtual port is a combination of a VLAN and a
port. The monitor port(s) can be connected to a network analyzer or RMON probe for packet
analysis. The switch uses a traffic filter that copies a group of traffic to the monitor
port.
Up to 16 mirroring filters and up to four monitor ports can be
configured on the switch. After a port has been specified as a monitor port, it cannot be
used for any other function. Frames that contain errors are not mirrored.
You cannot run ELSM and mirroring on the same port. If you attempt to
enable mirroring on a port that is already enabled for ELSM, the switch returns a message
similar to the following:
Error: Port mirroring cannot be enabled on an ELSM enabled port.
For high availability, you can add up to four redundant remote IP addresses.
When creating a mirror with this command, you can add one IP address. To add additional
remote IP addresses, use the configure mirror mirror_name {to
[port
port | port-list
port_list | loopback port
port] | remote-ip {add} remote_ip_address {{vr} vr_name } {from [source_ip_address | auto-source-ip]} {ping-check [on | off]}] {remote-tag
rtag | port
none} {priority
priority_value}command.
Standalone Switches and SummitStacks
The traffic filter can be defined based on one of the following
criteria:
- Physical port—All data that
traverses the port, regardless of VLAN configuration, is copied to the monitor port(s).
You can specify which traffic the port mirrors:
- Ingress—Mirrors traffic received at the port.
- Egress—Mirrors traffic sent from the port.
Ingress and egress—Mirrors traffic either received at the port
or sent from the port.
(If you omit the optional parameters, all traffic is forwarded;
the default for port-based mirroring is ingress and egress).
- VLAN—All data to a particular VLAN, regardless of the physical port
configuration, is copied to the monitor port.
- Virtual port—All data specific to
a VLAN on a specific port is copied to the monitor port.
- ExtremeSwitching series switches
support a maximum of 128 mirroring filters with the restriction that a maximum of 16 VLAN
and/or virtual port (port + VLAN) filters may be configured.
- ExtremeXOS
supports up to 16 monitor ports for one-to-many mirroring.
- Only traffic ingressing a VLAN can be monitored; you cannot specify
ingressing or egressing traffic when mirroring VLAN traffic.
- Ingress traffic is mirrored as it is received (on the wire).
- Packets which match both an ingress filter and an egress filter will
result in two packets egressing the monitor port or ports.
- In normal mirroring, a monitor port cannot be added to a load share
group. In one-to-many mirroring, a monitor port list can be added to a load share group,
but a loopback port cannot be used in a load share group.
- You can run mirroring and sFlow on the
same device when you are running ExtremeSwitching series switches.
- With a monitor port or ports on ExtremeSwitching series switches, all traffic ingressing the monitor port or ports
is tagged only if the ingress packet is tagged. If the packet arrived at the ingress port
as untagged, the packet egress the monitor port or ports as untagged.
- Two packets are mirrored when a packet encounters both an ingress
and egress mirroring filter.
SummitStack
Only
The traffic filter can be defined based on one of the following criteria:
VLAN, regardless of the physical port configuration, is copied to the monitor port.
- SummitStack supports a maximum of 128 mirroring filters with the
restriction that a maximum of 16 VLAN and/or virtual port (port + VLAN) filters may be
configured.
- ExtremeXOS
- When traffic is modified by hardware on egress, egress mirrored
packets may not be transmitted out of the monitor port as they egressed the port
containing the egress mirroring filter. For example, an egress mirrored packet that
undergoes VLAN translation is mirrored with the untranslated VLAN ID. In addition, IP
multicast packets which are egress mirrored contain the source MAC address and VLAN ID of
the unmodified packet.
- You cannot include the monitor port for a SummitStack in a
load-sharing group.
- You can run mirroring and sFlow on the same device when you are
running a SummitStack.
- With a monitor port or ports, the mirrored packet is tagged only if
the ingress packet is tagged (regardless of what module the ingressing port is on). If the
packet arrived at the ingress port as untagged, the packet egress the monitor port(s) as
untagged.
- You may see a packet mirrored twice. This occurs only if both the
ingress mirrored port and the monitor port or ports are on the same one-half of the module
and the egress mirrored port is either on the other one-half of that module or on another
module.
- The configuration of remote-tag does not require the creation of a
VLAN with the same tag; on these platforms the existence of a VLAN with the same tag as a
configured remote-tag is prevented. This combination is allowed so that an intermediate
remote mirroring switch can configure remote mirroring using the same remote mirroring tag
as other source switches in the network. Make sure that VLANs meant to carry normal user
traffic are not configured with a tag used for remote mirroring.
- When a VLAN is created with remote-tag, that tag is locked and a
normal VLAN cannot have that tag. The tag is unique across the switch. Similarly if you
try to create a remote-tag VLAN where remote-tag already exists in a normal VLAN as a VLAN
tag, you cannot use that tag and the VLAN creation fails.
The following example enables a mirroring instance named
"analytics_chicago_1" to mirror packets to the remote IP address 1.2.3.4 with ping health
check (default behavior) being performed on the remote IP address:
enable mirror analytics_chicago_1 to remote-ip 1.2.3.4
"analytics_seattle_2" to mirror packets to the remote IP address 5.6.7.8 from the source IP
address 10.1.1.1 without ping health check being performed on the remote IP address:
enable mirror analytics_seattle_2 to remote-ip 5.6.7.8 from 10.1.1.1 ping-check off
This command was first available in ExtremeXOS 22.4.
Redundant remote IP addresses capability was added in ExtremeXOS 30.4.
Platform Availability
This command is available on all Universal switches supported in
this document.
